does any one have some pics of their rails? thinkin about getting a set,but still not sure. and yes i know their was talk about this,im asking for pics!!
i wanna see their work!
There is a .75mm restrictor in the driver's side rail that can be drilled out to 1/16", and a FPRV that needs shimming. Other than that (cost = .25 cents), there is nothing need in the rail dept.
im not talking about the fittings the rail its self
http://tcdiesel.com/default.aspx
go check them out,they have a pretty good read about the rails,i want more vol. thats what im after
im still on a stock cp3,so the more vol. i can get the better off i will be,thats how i see it anyway. im not dead set on it,just thinkin bout it. thanks for the info!
I gained 0 mph and picked up no ET by going to a full ported rail... you are wasting your time
ok,did you log your truck? did it feal better to the seat of the paints? just because,you dont go fast dont mean it dont help. just asking ?? is all
chevy1925
yes i know it is,still wanna do some more small things befor i go really big with it,and when i do it im going stage 3 from shane,or diesel injection here in ky
chevy1925
Pat,
Are you saying that there is a restrictor in the rail itself or the fitting at the end of the rail?
