Synthetic Fluid and Tempature
paint94979
Beer Nazi
Sep 18, 2006
11,715
So I changed over to Amsoil 15w-40 1,500 miles ago which has been around 3 months. Ever since then I noticed when driving under 2100 RPMs on the highway my gauge will read 205-210. I then give it some throttle and the gauge then will go down to 180 fairly quick. And driving "normal" it fluctuates quite often more so then it has when I ran dino oil. This has been the first oil change using the Amsoil 15w-40. I have checked the level several times and it is always at the full mark not above. The truck has 34,000 miles on it right now. Any thoughts?
dynarex
Dec 27, 2006
54
ive run the amsoil 5/30 since new and have 45k on it now
i dont think its the oil causing a problem
sounds like a poor flow condition -maybe ck the water pump /serpentine belt for the fan and lower radiator for blockage
paint94979
Beer Nazi
Sep 18, 2006
11,715
Are you running the Amsoil bypass filtration also?
Not i am not. I am running a ACDelco oil filter.
I would agree with you if it did it while I ran dino oil. But for it to be doing it the second I changed to synthetic tells me maybe I need to change to oil again that way it will be 99% or more Synthetic.
Is it possible that the Dino and Synthetic together are causing the temperature sensor to not function properly?
Nick
sounds bad to me!,i think you should sell your car to me and that should fix this problom:joker:
How about once the RC is done we can just trade. Hell Ill pay for shipping and customs.:D
dynarex
Dec 27, 2006
54
you def should be running an amsoil filter
not fram or delco
and the myth of mixing dino and synth oil was valid 30 years ago when the 2 woerent compatible but today i dont know of any oils that cause a problem when mixed
i think its more of a coincedence and coolant related
air/cavitation will cause this concern(head gasket)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
not fram or delco
good info, Im going to start useing a amsoil filter
SmokeShow
6,818
Lawrenceburg, KY
got the bypass system going on at my next oil change. Which is when the dang filters get here. I'll also start running Schaefers 7000 syn. engine oil.
C-ya
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
I started using Mobile 1 and with this cooler weather 40 - 60 deg., i'm seeing +- 185 deg. temps :)
dynarex
Dec 27, 2006
54
Whats the difference in the Amsoil filter and the others :confused:
the same difference as synthetic oil and regular
amsoil filters are synthetic
lots of othwers are paper and fall apart/clog quickly
youll be suprised how soon the filter gets restricted and gets bypassed
