LB7: Swapping my 6.0 into a lb7
Lb7joezay
I have a 02 Chevy Silverado 2500hd 6.0 short wheel base that works but I want to swap out a lb7 donor truck into my 6.0 but I need a bit more info on the swap
Lb7joezay
Sorry I was in a bit of a rush. I'm taking out the gas motor to put in a lb7 motor and a 5 speed Allison trans I wanna make sure if it's possible with the wiring. Can I keep the wires coming out of the firewall (cab) into the fuse box?
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
So long as you stay in the same generation, the swap is fairly easily doable. So for your 02, you would need an 01-02 lb7 and harness's to put back in it. Also I believe there was some differences in the pedal support due to the drive by wire pedal assembly vs the cable on your 6.0.
Lb7joezay
Thanks. I have an 02 lb7. Well I guess I'll be doing the swap then. Will I also need to get the pedal assembly?
