Is it possible to swap the tail housings between a 2wd and 4wd? If so how easy is it to do?
WisconsinHick1 New member Mar 11, 2009 1,231 1 0 Minnesota Mar 20, 2014 #1 Is it possible to swap the tail housings between a 2wd and 4wd? If so how easy is it to do?
S S Phinney Active member Aug 15, 2008 4,008 18 28 Quncy, Fl Mar 20, 2014 #2 You need the out put shaft and a spandrel nut I believe. Sent from my XT1080 using Tapatalk
WisconsinHick1 New member Mar 11, 2009 1,231 1 0 Minnesota Mar 20, 2014 #3 S Phinney said: You need the out put shaft and a spandrel nut I believe. Click to expand... What's the spandrel nut?
S S Phinney Active member Aug 15, 2008 4,008 18 28 Quncy, Fl Mar 20, 2014 #4 It may not be called that but there was a nut used for adjustments I believe there near the output shaft that was different. Sent from my XT1080 using Tapatalk
TheBac Why do I keep doing this? Staff member Apr 19, 2008 15,694 1,972 113 Mid Michigan Mar 21, 2014 #5 Just make sure to do the swap with the trans out, tailshaft up. Not recommended to try it in the truck.
