is surging during acceleration a sign of fuel rail pressure fluxuating and not staying constant. and if so will a lift pump cure this.....???
Pat whats your opinion on the shim kit/race valve debate? Some people say you will blow something up with a race valve on a truck thats driven much, others say they have a race valve and no ill effects.
There was alot of debate about whether a solid PRV or shimmed was a safety hazard. After thousands of trucks running shims and race valves, I've yet to hear of one problem that I would clasify as highly dangerous.
Usually, a problem is when they shim the valve wrong, or don't screw it in tight, it can make the truck run like crap, and sometimes leak a small amount of fuel. Very rare though.
2 shims is the correct number right? 3rd in the kit is an extra?
Thanks Jason. Its weird mine pops on a smaller tune than 500, but wont do it on the Race Tune. Gonna tackle it tomorrow.
So DRacing... sounds like a lift pump is next on your list?
