LB7: Surging after Lockup
Dura-Ration
You Shoulda GotA Diesel
Jun 20, 2008
128
66
Escatawpa, Ms.
I have a surging at highway speeds of 55mph & up. It seems to be worse when engine is still cool & right after Torque converter lockup. It will continue to do this until it reaches 195*. And then it will be occasional. This has begin going on for about 5 months, but recently gotten worse. Any suggestions would be helpful. Is there a sensor that is dirty or something else ? One more thing, it was doing this before the Allison was built to stage 4.
skintback
Take this one to church
Mar 5, 2007
919
Florida
Mine seems to do the same thing I think it's do to the LBZ pump on a LLY/LB7 and a slightly moded reg mine does it after the converter locks 48-55mph then goes away. It is annoying
Dura-Ration
Jun 20, 2008
128
66
Escatawpa, Ms.
Well maybe not. I'll have to try my stock tune to find out. But Like Skintback said I do have a LMM CP3. And it idles up and down on the stock tune.
Dura-Ration
Jun 20, 2008
128
66
Escatawpa, Ms.
Well I tried the stock tune and it made it less noticeable but still there. Play with B1010 ? I looked at it, but I don't want to play. :badidea:
:help:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
:help:
Start with copying a LBZ table and pasting it in your LB7 tune . from there, if that is not enough............ you need to log, " MM3 per second" ( GM.FUELQ_MAIN_DMA ) and find the amount of MM3 per sec that the surging occurs @ and increase the "MA" per that box .
Dura-Ration
Jun 20, 2008
128
66
Escatawpa, Ms.
whoa nelly. me no undertan efi the live. MM3 7 dma per second What ?
I appreciate the help but I would have a melted motor by the time I figured it out. I'm mechanical not compootered.
The surge feels like a cylinder has a miss. I have logged a tune several times and have found nothing. But what do I know.
TrentNell
Jul 7, 2008
7,543
slc tuah
Post up a log , if you cant see the rail pressure fluctuate when the surge happens the previous mentioned fixes will not work . If you cant work EFI then contact who you bought it from to see if they can help out .
