Super Diesel Lift Pump - What filter?
radvans
242
SoCal
Need a new filter for my super diesel lift pump. Its a perm cool I believe but not sure where to get them. Sent a im to SD but haven't heard back and need to get the filter replaced before Friday to tow.
Also, with this setup how to do you replace the filter without fuel running out? I started to remove the filter and was surprised to find the filter can't be removed like the stock one.
radvans
242
SoCal
Found this info on another site. Posting here for future reference.
The main reason why you want the CAT High Efficency Filters is they Filter Down to 2 Mircron, block water, and handle frozen/gelled fuel better.
Cheapest easiest, simplest way to add a CAT Filter is to purchase a Permacool Fuel Filter / Water Seperator Kit ($35.88 at Summit Racing.) and a CAT 1R-0750 filter from a CAT dealer for about $11.00.
Permacool makes 3 filter heads that use the 1-14 Thread (which is what CAT uses on some filters).
Perma-Cool 88864 High Flow Filter Head (3/4" NPT Inlet / Outlet)
Perma-Cool 81794 High Performance Filter Head (Dual 1/2" NPT Inlet / Outlet)
Perma-Cool 81074 Universal Fuel Filter/Water Separator Kit
The CAT filters Thread up to the Permacool Filter heads Perfectly.
CAT Filter on a Permacool Head
I have used / expeimented with different Perma-Cool Heads and CAT Filters with my Vegoil Setups.
The 1R-0750 Filter should flow plenty big enough for any 8 Cylinder engine but, if you want to go nuts get a 1R-0749 Filter ($16.00 at a CAT Dealer), it's huge and also works with the permacool head. I have one on the Permacool #88864 High Flow Filter Head on my Vegoil Prefilter.
It works OK but, clogs pretty quickly so I will probably not keep using it on the pre filter. I am looking at some CIM-Tel filters to try on the prefilter next.
The two micron filters are used usually as secondary filters on newer rigs and there is usually a higher micron rating water seperator / filter before the two micron. Like a 175-2949.
For the past couple of years though CAT has been subbing the 1R-0749 and 1R-0750 for higher micron rating filters like 1R-0712 (10 micron) that are the only fuel filter used on older rigs, read this page. So they can be used in single.
I have seen allot of debate on different diesel sites that other manufactures X-ref filters aren't as good as CAT's. At $11.00 and $16.00 a pop for the Original CAT's I'll stick with them but, a while back I did make up a Cat Filter X-ref in case I ever needed a filter quick.
Caterpillar Primary Filter/Water Separator 175-2949 (threads 1-14 UNS-2B )
Fleetguard FS19683
Donaldson P551743
Baldwin BF1268, BF1214
Fram PCS5063
Wix 33005
Luber-Finer LFF8030
ACDelco TP1002
NAPA FIL3005
Purolator F60026
Hastings FF864
Caterpillar Secondary Filter 1R-0749 (2 Microns) (threads 1-14 UNS-2B )
Fleetguard FF5319
Donaldson P551311
Baldwin BF7587 (BF614, Standard Version, BF7633, Short Version)
Wix 33674
Luber-Finer LFF2749 (High efficiency version of LFF5823B)
ACDelco TP1322
Fram P8335
NAPA FIL3674
Purolator F75185
Hastings FF1056 (FF1007, Standard Version FF1079, Short Version)
Caterpillar Filter 1R-0750 (2 micron) (threads 1-14 UNS-2B )
Fleetguard FF5320
Donaldson P551313
Baldwin BF7633 (BF7587, Long Version)
Wix 33528
Luber-Finer LFF3347
ACDelco TP1326
Fram P8334
Purolator F65213
NAPA FIL3528
Hastings FF1079 (FF1056, Long Version)
found on this site.
http://www.gm-diesel.com/diesel/vbull/showthread.php?t=15406
