Just had Stage-4 Suncoast transmission Installed , Finally get to Try out
PPE-HOT-2 Programmer on #5 Setting , Transmission Seems to be learning Pretty quickly, Noticed some confusion from 4 to 5 Gear at first when I would step into it .
Had AAmco install the Down Pipe at the Same Time.
Unreal how you can feel this Tranmission get the power to the ground with this Stage-4.
also included the Mag tech Deep Trans Pan that holds the addtional fluid I fugure this will Aid in cooling . Temps seem to stay lower than the stock trans did already by 30--50 degrees.
