Suncoast help!
AJ500
May 25, 2010
32
I am currently building my transmission and have a few questions. Is anyone available for some tech support?:eek:
AJ500
May 25, 2010
32
My question is on the c3-5 pack with the suncoast steel plate that goes under the piston return pressure plate there is not enough room to compress the pack to get the snap rings back on top.. so i guess my question is do i have to eliminate a clutch pack?
Any help appreciated:confused:
kenny
kennydiesel
Mar 5, 2009
319
washington state
I don't recall having to compress the stack to get the snap ring in? A little pressure is all I needed to fit it together. Pretty sure nothing goes between the piston and apply plate. First plate on top of apply plate should be friction plate. Need to make sure the pack has the proper clearance when loaded in housing with snap ring installed.;) This is very important. You should also easily be able to spin the planetary sun gear without feeling the pack drag. Hope this helps others that read this as he has probably corrected this issue.
