Sump
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I've got a fass sump waiting for me to install it in the 01.. Looks great in excited to try it out.
Dallas S
486
33
Alberta
I run an old sik dmax. Nice unit. The two piece inner ring can be a pita to line up. Just installed an xdp, single piece interal ring with a slit so no tank drop and little easier to line up IMO. The new fass sump with top draw is pretty neat..
slipclutchms
427
I like the XDP. I think the beans is the one with a "single bolt" correct? Im not as big of a fan of that design.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
Yes it is the single bolt style. 1 bolt or 10, they do the same thing, but i do like the fact that you don't have to worry as much about a uneven torque on the gasket and leaking as much.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I'm using the fass without the straw, tank will be out of the truck when I install it. I'll be sure to take lots of pics
02greysixer
1,829
North Central FL
I installed the fass sump in an lml last week. Really nice kit. I think that's what I'll be putting in my truck unless I score a major bargain on something else
LBZ-DURAMAX
Jared
Feb 12, 2015
193
NW Ohio
I like my beans sump quick install and no leaks... Great product not the best customer service I left 6 voice mails over a period of about 2 weeks and no call back I ended up catching someone on the phone eventually
moparkxracer
2,309
33
Out and about
I'm using a helman and a XRP I like the gasket on the helman better both look the same. I didn't want to run the dual outlet sump, IMO it would swirl the fuel when level is low. Kina like a toilet. Had both installed abt a 6 months no leaks so far.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I ended up ordering the beans one. Its not the gasket that scared me away from the xdp style but the plastic washers on the bolts. Not a fan of them.
LBZ-DURAMAX
Jared
Feb 12, 2015
193
NW Ohio
Not really other than when you start to cut the big hole start in reverse to help not make a rough edge but I'm sure you'll be fine :thumb:
