sump or draw straw needed with fass?
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
I was going to install a fass 150 on my 15 lml, and I've been hearing different things on what's all needed. Do I need to install a sump or draw straw in the tank, or just run off the stock pick up?
Posted via Mobile Device
Digmax
289
Stock pickup. I have a 10 mm stroker pump and other day my air dog had blown a fuse and I didn't know it and still made 29k on my big tune
Sent from my C811 4G using Tapatalk
CarolinaHD
969
NC
Pump is louder without a sump/draw straw. Just installed one on a friend's 2013 and he commented on how loud the pump was (still has factory exhaust). Called fass and they said there is more restriction in the factory lml pickup and that installing a sump would make it quieter.
So i take it as the pump has to work harder to pull through the factory setup and the pump will wear out faster :confused:
Digmax
289
My brother has a sump and is ridiculous loud
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Sump is the way. I also am a big believer in the Beans Diesel sump. No leaks no mess. One hole to drill (hole saw provided) and one bolt to torque everything down.
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
I've been wanting to try the Bean's sump. Seems everyone likes it. We install a sump with every 15+. We've had trucks run much worse with a lift pump than without if we try to use the stock pick up tube.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Rule of thumb in hydraulics, the suction side is should be larger than the pressure side otherwise you will get cavitation or noise and prematurely wear out the pump.
The larger corrugated pipe is the supply and then reduced in size at the nipple (2011 truck)
Here is picture of the cup in the LBZ/LMM trucks.
