Suggestions on setup
05chevy
1,086
I have been having problems with my front end raising alot when I pull. Keys all the way down, drop shackle in the rear, springs clamped, bump stops, traction bars. I have everything needed for pulling just trying to figure out why my front lifts so bad? Should I put the stock shackles back in? Any suggestions?
05chevy
1,086
Here is some pictures. Ill try to find a video
AdaMax
Nov 26, 2010
412
Caldwell , Oh
Looks like you have a lot of rear squat with the sled on you . Are you allowed to run suspension stops ? You could also take out the front bump stops and replace them with solid 2" cold rolled steel ( Installed only when your going to pull ) .
05chevy
1,086
I have rear bump stops set at 1" travel. The front stops are out. What would the blocks do for me?
