I have an '05 GMC 3500 Duramax 6.6, the truck has less than 200,000 miles and less than 3,000 hours. One day I was on my way home when the truck shut down (as if the key had been turned off) in the middle of the road! Whenever I turn the key to Start the truck all the gauges drop like it would when it would normally start, but it wouldn't crank. not a single noise. i tested the starter and it works fine. replaced both batteries and cleaned the terminals spotless! still no crank. however i can pull the relay in the fuse-box and we can jump the wire holes and the truck will crank. but not start. i'm really tired of having this 2 ton beast just sitting there mocking me... i need any help you guys can give me, a while back i replaced the water pump with a new one and i pinched a wire and the truck would crank, but not start. could that possibly be tied in with this butt load of headache???
