Stuck in limp mode
hd.ride.hard
Aug 31, 2013
5
3
05 stock tranny will not come out of limp mode
208001 original tranny
tried to reset by shutting off removing key opening door starting backup
goes right back into 3rd after bang
no tuner on truck
just bought it this year and I do not know if it had been tuned before most likely had been
baddaddition
Mar 10, 2013
287
Is the t case leaking yet? Any codes?
Sent from a greasy hand under the hood of my buddys truck.
hd.ride.hard
Aug 31, 2013
5
3
Transfer case not leaking
This happened on the way to work this morning I will not be able to get the codes till I get home
2 weeks ago same thing happened in the Bronx New York had it towed home the dealer told me the next morning everything was fine
there were
three codes
2nd gear ratio
e valve stuck
and 1 other one
I'll have to get them when I get home
KOoner
Mar 22, 2014
27
Ohio
Try cycling the key 3 times. Shut the truck off turn it to run then back off. Do that three or four times in a row. Then try driving.
hd.ride.hard
Aug 31, 2013
5
3
Truck doesn't move anymore
Three codes
732 incorrect 2nd gear ratio
777 pressure solenoid b controlled clutch stuck on
842 trans pressure switch solenoid e stuck closed
