LB7: stuck in 4x4hi
dirttymaxx
Nov 15, 2010
334
sharpsburg,ky
ok,so it rained sunday at the farm,ran the tractor outta fuel...jump in the truck..go hook to the tractor,put the truck in 4x4..then service 4x4 light comes on..
pulled codes tonight...found C0327 Encoder Circuit Malfunction
so i guess the motor is shot..right? i reallt dont wannt drop $300 on the wrong part ya know.
02 lb7 auto 3500 with 240 miles
2004dmaxxx
Jun 12, 2012
Lancaster pa
is the light for 4x4 on in the interior or is the truck actually stuck in? dumb guestion i no but when my guage cluster was goin out the 4x4 light was on n i had service 4x4 light on too
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
there are 3 bolts to take the motor off and you can plug it in and have someone hit the button and see if it turns,if it does grab an adjustable wrench and see if the manuel part will turn atleast that will tell you if is the motor or the tcase
