Stuck in 2 gears?
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
Got this truck 2013 w alli. Put it in drive or reverse and its locked up wont move. put it in
neutral and pow it rolls. When I got it it had a bunch of codes for all the solenoids and tft (Low(* no gnd. was low battery. It had a code in ot for 6th incorrect gear ratio? I furget the exact. how does it even gt that code when batteries were removed AND has had all codes cleared. Has not driven since. Any silver bullets before I take it out for rebuild? Rather not.
Thnks fellers
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
PSM logic lines up with chart for pressure witches.TFP switches line up with chart as well. looks like something internal broke or cracked and crossing pressure in clutches. Well sheet
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
Well thats odd. run through scan tool shift pressure tests all good BUT. After run through it cluck\nks in some gears. let foot of brake and its in gear running about 30 mph. Im guessing Limp. put it in rev and locked. did this twice for fun second time ran at 30 ish then I was looking at scan tool. Looked up found 0 mph and locked up again. Must be busted drum or some shit cross leaking inside?
