LB7: Strange intermittent power loss??
CDR
Apr 19, 2009
84
Well Here it goes LB7 2001 with 2002 OS system MBRP exhaust ARE intake. Here the issue with a stock tune it runs perfect. The second I do anything as far a tunning it develops an issue. Now I know what everyone is thinking I don't know how to properly tune so I bought a PPE tunner and it did the same thing....
From a dig floor it hammers off the line all the way to 100mph no problems
From a roll barely will accelerate when floored. goes faster if petal is at %50 rather then %100 Rail pressure is perfect is perfect throttle sensor registers %100
If you stop dead and go from a dig it will accelerate perfect again
Im lost any help I would appreciate!
CDR
Apr 19, 2009
84
When this happens fuel always restricts to 32mm!
Please some one help me!:(
CDR
Apr 19, 2009
84
Have not shimmed or bottle tested it. Again rail pressure is on point but the the commanded MM's won't go higher then 33mm when this happens
CDR
Apr 19, 2009
84
No not at all. I hope I'm explaining this right. From a dig it run perfect! normal smoke good boost. from 30 mph if you floor it almost NO boost only 33mm commanded injector.
CDR
Apr 19, 2009
84
I can't figure out how to upload the log file if anyone wants to take a peek I can email it
02greysixer
1,829
North Central FL
If you have efi why not disable the egr and see how it acts?
Maybe the egr is opening at part throttle and when you hammer on it the turbo blows it open? I'd guess it's closed at idle and the turbo can't blow it open from the fully closed position. Just grasping at straws for you
sent from a galaxy far far away
