Stock LLY baseline dyno
Phiber Optik
Former PowerStroke Owner
Apr 24, 2011
3
BC Canada
I just got my 04.5 LLY truck on saturday and already have parts on the way but i wanted to dyno in stock form before i started modding it
here are the dyno results, how do they look?
266,000kms (165,000mi) drivetrain, allison 5spd, 265-75-16 tires
everything is stock, except a hole is cut in the lower half of the airbox and I did the pcv re-route.
Utahski
Oct 20, 2008
546
Northern Utah
First time on the dyno, my LLY did 235/441..... with Edge Attitude on stock settting and 4" exhaust no cat. It was a Mustang dyno at 4300' elevation, no correction factor.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I wish that I had gotten a base line on mine when stock. I just put mine on the dyno for the first time this weekend. My LLY is all stock except for the Edge w/Attitude. I put it on level 5 for the dyno and it made 430 hp / 818 Tq
man I ran mine a couple months ago on a junk dynojet. ran it with PPE on level 10, 4" intake, rdl turbo inlet, manifolds/up pipes, 4" down pipe, 4" exhaust, 150 gph lift pump, and a built trans. put down only 414hp 777tq. it only pushed about 21psi of boost because it was an inertia dyno
dieselboy04'
DieselBoy04'
Mar 23, 2008
135
Virginia
I went to L&N dyno days a few years back and watched some guys with basically stock trucks do some crazy stuff. They were passing around a PPE Hot ET+2 and the first one to go set his on the highest tune. the 425hp over stock I believe it was. truck smoked like a freight train but only put out 380 some hp. I suggested to the next guy to back it down a few settings and when he got his pulls, the best he got was 447 I believe it was. pretty much the same trucks, same tuner on Dunn bars dyno. some times less is more unless you have the hard parts to back it up.
22eco
I love my D-Max
Nov 4, 2009
32
Arizona
I wish I would have done a stock dyno. The last time I put it on a dyno it made 360hp / 660tq at that lever it didn't limp the tranny sense then I done a little tweaking and now it limps the trans I need to put it on the dyno so I can see what its making now..
