I have a 2007 Duramax LBZ with about 360,000 on the truck when the motor decided that it wanted to spin rod bearing on the crank, which resulted in the piston to touch some of the valves.
The valves nor the pushrods look bent. However, the piston does show where the valves hit. The crank also does have some wear on it where the connecting rod attaches.
I am looking to get the truck up and going as soon as I can, but I am not sure on what my rebuild options are. I would replace the push rods & the valves b/c if they touched I am going to assume they are bad (don’t want problems down the road). This truck is staying completely stock as it is a DD :baby: (no need/want for performance build).
I have heard from some people that I have called around that the crank can be turned, and others say it is a bad idea.
1. Can the crank be turned and still be reliable?
2. Is there a 'stock' rebuild kit, out there for a reasonable price?
3. Or would it be better/cheaper to bag it all and throw in a used motor w/about 169k miles on it?
