Ok, so some crank failures have been seen in high output efforts.... To help combat this, as far as I know, the most common thing done is to use main studs. Every once in a while, while digging on the interwebby, I read about main girdles on our trucks. What I don't know is if anyone is using one yet. It sure seems like they would help add strength and stability to the crank, no??
Some things that I've read along with the use of girdles is that, while they do add strength and rigidity to the lower end of the engine, the lack of the same rigidity in the top end can introduce new problems up top. IF this is the case, what, if anything, do you then do to the top end to add strength and stability up top as well? Is there something up top to girdle or brace?? Sorry if that's an elimentary question.
Just digging for more information just for the sake of my own curiosity and knowledge.
C-ya
C-ya
