Stock 2015 radio
Rakotz23
Mar 19, 2015
Anoka, MN
I bought a 2015 2500 wt, it has the stock 4.5" screen display radio. I am wondering if it is possible to add a back up camera and bluetooth. Not looking to add the full mylink just seeing if adding the two options are available.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
The bluetooth is integrated into the OnStar system. If it's a base model more than likely you're out of luck in regards to bluetooth. The backup camera may be a possibility but the radio will need GM to reprogram it to know it has one.
chevyburnout1
Aug 25, 2008
2,368
Berthoud, CO
To tell you the truth I have not messed with the new body styles so I'm not too up-to-date on if they changed from previous models. But if they are similar the OnStar module will have a bluetooth antenna on the outside of it.
