I got my KD Twin lift pump kit installed a few weeks ago, and am still having rail pressure problems. It's better than it was (Used to drop to about 60MPa when commanding 159, now drops to 125 or so).
At Eric's SF last weekend, I had my truck on the dyno and put down 446/820 with the PPE 330 tune. I had Dunbar log my runs, and found that then he went to 100% TP, the rail pressure dropped about 5200PSI almos right away (after about a quarter of a second), and over about 2.5 seconds, built back up to 20719, dropped back to 18760, then built back up to 19674 until it spiked when he let off the throttle.
I found it won't hold pressure with CIT1991's Economy+120 tune either.
When logging, I noticed that while rail pressure is building back up, the FRPACOM mA value remains lower than the FRPADES mA value while dropping until I let off the throttle.
I've got the PPE race valve and KD twin pumps (which I've verified are making over 7.5 PSI). I've attached a short log from one of my "pulls" with the "economy" tune.
Any suggestions what I should look for? I've checked the race valve (It's on SUPER tight), but I'm not sure what else to look at.
Thanks
Thanks
