I've heard of regulators sticking, but never dealt with one personally, just dealt with bad regs that go straight to max rail..
Very interesting issue here. Truck holds perfect rail on the FIRST wot pass all the way through the gears. Then when you let off, both desired and actual go to ~9k.
Here is where it gets interesting. After this first run, both sitting at ~9k on 0% throttle decal, if you begin to tip into the throttle again desired moves up as it should and actual stays right at that 9k mark.
The only way to get actual to move along with desired again is to slow down under 40mph, where desired drops under 9k. As soon as actual moves even a hair it is good to go again.
Example: you go wide open on the on-ramp of the freeway, get up to speed, and set the cruise. You will cruise at 9k actual indefinitely (with desired jumping around 10-11k, until you slow down to 40mph or so.
I tried blipping the throttle quickly once it is in this condition to try to get actual to move and it stays flatlined at 9k rail.
Exact same issue happened both before and after lift pump.
Any ideas? I cant say ive ever seen or even heard of this.
