Help: Steering wheel controls stopped working...
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
The steering wheel controls quit working on my 03, the volume control and seek funtion works but none of the other ones work.
Is it my cluster going out? It is a newer cluster since my factory unit went out. I would like to get these working again
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Could be the buttons in the wheel or broken wires,probably have to figure out which wires coming down the column and make sure you have continuity on those wires the switches come out easy enough.
Big Block 88
Nov 3, 2008
4,665
Got some extra wheel controls, should pull the old ones this weekend, my old button are worn out anyway. I will check cont..
I just thought I had read somwhere that a cluster could cause issues??
ryan415
Oct 24, 2012
371
860
Did it happen after you replaced the cluster? Cluster will need to be programmed in that case.
Nightlb7
175
Maryland
Did you ever find out what was causing this??
03 2500hd lb7, ccsb, robs trans safe tunes, Airdog 165, profab horn, 4in straight piped, ppe gauges, cognito control arms and braces, banks big head waste gate, batmowheel in the stock IHI. Built trans and engine coming soon :)
