I have a 2003 Suburban 2500 Quadrasteer (w/a LB7) and the steering box input shaft seal started leaking. The box still feels tight, just leaky.
I believe the part number is 19330624, and it appears that box is unique to the Suburban 2500 platform (including Yukon XL 2500, H2, and Avalance). Takes 2.75 turns of the steering wheel to go from lock to lock, but I don't know if it is constant or variable ratio. It appears only reman boxes are avaliable, which I am leery of.
Since the front of the Suburban is now a lot heavier with the diesel, I think the truck box might last better, assuming it has the same ratio and bolts up. My stock box is long gone on the truck, so I can't count turns. I have the bigger PSC box and it is 2.5 turns lock-to-lock, so (assuming it even bolts up) I can't use that with the Quadrasteer. I am worried it will cause the rear end to steer too little and lose the epic turning performance I have come to know and love.
What would you guys do, try and get a seal kit and see if that fixes the leak, or swap it out for a Red Head or similar reman?
Anyone ever change steering ratios on a Quadrasteer vehicle before?
