As much as I'd love to read off my list to you I'd much rather figure out what crank I need for my motor.
Well your build list would be beneficial for us to look over in order to see what you need.
Stock lb7 or lly crank. Carillo rods, fingers cast Pistons, arp headstuds, main studs, flex plate and bolts, you'll want to have the entire rotating assembly balanced too. Internally is better. Clevite bearings, engine gasket kit, new oil pump, pinned water pump, etc.
Then there are pushrods, heads, valves, springs, rockers.
Then there is injectors, cp3's, lift pumps, billet hold downs, atleast 6k+ in turbos and kits, manifolds, up pipes, inter cooler, etc.
It will not be cheap. If you want a true 1000+ hp street truck build right, I would say it's safe to say expect $7-8k in the short block, 2-8k in headwork (depending on what heads you get), 2-3k in fuel mods, and another 3-7k in turbos. Plus all the accessories, aftermarket radiators, fans, stainless lines, etc. those numbers are on the low side too imo.
