I have a stage 4 suncoast with a 1056 thats never seen over 500 hp and has around 65,000 miles on it now. ever since it was built i have been getting stuck solenoids every 10,000 miles i have been replacing them either 1 or two at a time and they all have been replaced. now my problem is starting all over again the truck is throwing codes you cant drive down the road with out EFI lilve hooked to it clearng codes it starts in 4th gear fluids are getting to 200 plus degreese. and every time i drop the pan there is always a 1/4 inch of sludge in the bottom. The trans was built by a very good allison builder that has built many of them before both stock and suncoast.
how many miles does a built allison last that has been raced and pulled at my level?
could the 1056 be self destructing?
also every 5,000 miles the spin on is changed and it is full to the top with sludge every single time since the time it was built. you cant tell the difference between tranny fluid and engine oil thats how bad it is.
Some one tell me where to go with this
