Sorry in advance for the long post.
Here it goes: My LB7 that is currently in my square body had developed a few issues that I feel are indicative of a spun main bearing, but I'm always open to second opinions. Being a mud truck, it turns 4500 RPM pretty regularly, and gets beat on most of its life. At the last event, after beating on it all night, I noticed VERY low oil pressure when the engine would come up to temp (5psi at Idle). Also, when cold, the engine starts as it should with no effort and the oil pressure is great. But, after getting up to temp, the starter drags very hard as if the batter is dead (have already replaced battery and starter). I drained the oil and found no evidence of metal in it, but it hasn't been ran much since the problem developed. It still runs as it should and isn't making any bad noises, just low oil pressure when warm and dragging on hot starts. I'm leaning towards that I have spun a main, and when it gets warm, it is creating extra friction in the bottom end, causing the dragging and low oil pressure. Thoughts? TIA for any opinions
