Got about 15,000 on my truck with about 10,000 on the SCIV. Seems a fair amout of fluid is dipping from the under side of the cab and exhaust and cross over member. I pretty sure its coming out the transfer case rear seal. The trans and transfer case are both clean and dry. Is this something to worry about or just a simple seal replacement? Is this normal on modded trans? I have some pump spring mod to up the pressure in the trans all the time (i thinks).
