Speedometer only works when I push the brake pedal
DmaxRvRrat
Mar 19, 2014
82
Speedometer only works when the brake pedal is pressed (brake lights come on). Cruise control doesn't work either. Tested the brake pedal switch, replaced it anyway, didn't fix it. checked all of the wires under the dash best i could.
Anyone know what would cause this? :confused:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Any codes? Sounds like a short in the VSS wire from the ECM to the cluster.
Pull the cluster out, and look for the dark-green/white-stripe wire. I forget what pin position off the top of my head.
Use a multimeter and check for voltage between that wire and ground (key on engine off, and then check with engine idling). Then press the brake pedal and see if the voltage (if any) changes. It sounds like the TCC/brake circuit (which is +12v with brake released and 0v with brake applied), its the purple wire going to the brake pedal switch, is somehow feeding into the 4k ppm VSS circuit.
Ben
DmaxRvRrat
Mar 19, 2014
82
No codes....I've got the cluster out, there are two green and white striped wires.
DmaxRvRrat
Mar 19, 2014
82
DmaxRvRrat
Mar 19, 2014
82
I tested the green/white striped wire on the left side in the picture. I believe this is the VSS wire in A3 position on the connector.
This wire has 12V with the key on engine off, and once the brake pedal is pushed it has 5.5 V.
With the engine running this wire has 14V, and once the brake pedal is pushed it has 6.5 V
Any clue as to what could be causing this? :confused:
Thanks for your help!
DmaxRvRrat
Mar 19, 2014
82
Also tested the purple wire at the brake pedal switch and it has the same voltage that the VSS wire at the cluster has, and acts the same when when brake is applied.
trashygasman
Slowly but Surely
Dec 18, 2008
637
49
Washington, OK
Check to make sure all your fuses are getting good contact. My truck was doing some wierd stuff a while back and one if the ECM fuses under the hood wasn't getting good contact.
DmaxRvRrat
Mar 19, 2014
82
Ok, I will do some more digging today.
Might have stumbled upon another clue last night. With the key off, the cruise and high beam indicators on the cluster light up dimly 10 to 20 seconds after everything is left idle. (turn lights on or key on and they go off)
Could the multi-function switch at the column cause the issue I'm having i wonder? :screwy:
DmaxRvRrat
Mar 19, 2014
82
I'm not sure I know what you mean by adding another ground
DmaxRvRrat
Mar 19, 2014
82
Still trying to diagnose this....pulled the switch off the column and found this
DmaxRvRrat
Mar 19, 2014
82
Well, the speedometer doesn't work with the connector unplugged at the multi-switch, must not have anything to do with this problem. I followed the wires all the way to the fuse box, couldn't find where they would be physically shorted.
Ben, is there a module or something that uses both of these wires? I unplugged the ABS module on the frame just in case, but that didn't solve it either.
DmaxRvRrat
Mar 19, 2014
82
Found the cause of the issue finally!! Mouse got underneath of the fuse box and did some damage.
Sierra2000
Oct 29, 2016
2 1/2 years later and thanks for this tip. I have the same chewed up wires under the fuse box under the hood. Once I got you in and had a look I could see GM designed nice little entrance doorways for the mice to come into from the cold and all those wiring harnesses... Nice when these trucks just had a simple speedometer cable from the trans to the dashboard. Never had a mouse chew into one of those. Thanks again - Happy Holidays.:hello:
Reply to #16
DmaxRvRrat
Gearhead
Feedback Score: 1 reviews, 100%
__________________
'01 Sierra
30 overs, EFI, Built Trans
Grizzly locker, Sleeved and Braced
Lift Pump, AFE Intake, Horn, Straight Pipe
4" lift on 35's.
