Having a bit of a battle, wonder if anyone has conquered this.
The truck is an 08 LMM, runs on 37" tires & just swapped to 5.13 gears.
Shift points are fine & ABS lights are off with 5.13 in the axle ratio.
At 30mph on the speedo, the actual road speed GPS'd is 38mph.
Tried adjusting the gear ratio calculation, speedo gets close, but then I'm throwing ABS codes.
Any help would be appreciated
