When changing tire size, can I just change the height and be ok?
SHOTZY <"Whats next??" Aug 27, 2008 474 0 0 melbourne, fl Feb 27, 2010 #1 When changing tire size, can I just change the height and be ok?
SHOTZY <"Whats next??" Aug 27, 2008 474 0 0 melbourne, fl Feb 27, 2010 #2 SHOTZY said: When changing tire size, can I just change the height and be ok? Click to expand... Lol. Sorry, I meant with efi in the speedo calculator section.
LBZ Super Moderator Staff member Jul 2, 2007 9,905 151 63 46 B.C. Feb 27, 2010 #3 There is a calculator in EFI LiveI think for the LLY OS that you can use and is pretty accurate.
L LBZrcks ......... Jun 2, 2007 5,297 12 38 39 SoCal Feb 27, 2010 #4 Also don't program it for a size larger then 35's or you will get an abs light.
THEFERMANATOR LEGALLY INSANE Feb 16, 2009 3,890 44 48 44 ZEPHYRHILLS, FL Feb 27, 2010 #5 LBZrcks said: Also don't program it for a size larger then 35's or you will get an abs light. Click to expand... I think that only happens with 06+, 05- don't use the BCM for the speedo circuit like the 06+ does.
