Speed related calculators
13,749
821
I made a spreadsheet a while back to calculate RPMs based on speed that I had posted on DP. I had later modified the calculator to be a little more user friendly. Unfortunately, before I could ever post it, I lost it.
Anyway, I made up some new calculators today. I didn't really know where to post the spreadsheet, so I figure I'll throw it in here.
The first spread tab is the same spreadsheet I made before. It's pretty self explanatory, but if you have questions, feel free to ask.
The second tab is a comparison that can compare either speed or RPM between two different setups. You can compare different tire sizes, axle ratios, gears, or transfer case ranges in any combination.
The third tab is a speedo calculator thing. It calculates how tire sizes change your speedometer, and it will help calibrate your speedo with EFI if you have a GPS.
Let me know if you have any problems and how you like it.
  • calculators.zip
13,749
821
It keeps a row or column value in a formula from changing as it is drug across a range of cells. For instance. If I were to type $B16 in a formula, I could drag that formula down into lower cells and the B would not change. I could then drag it across and the 16 would change. Whereas if I were to type B$16, the B would change as I drug it down, but the 16 would not change as I drug it across. If I were to combine both as $B$16 then neither would change as I drug the formula down or across. Make sense?
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Thanks Josh.
We should make a suggestion to change the board to allow excel spreadsheets to be posted. I tried this one the other day for ecc_33 and couldn't.
I'm a CPA so I like spreadsheets.:D
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Thanks Josh.
All you have to do is zip it and then attach it :D
13,749
821
Thanks Josh.
Make sure you look at the tabs at the bottom. I believe the calculator in the second tab would be very useful for someone who is a sled puller...
