ENGINE COMPRESSION TEST
Tools Required
J 26999 Compression Gage
J 26999-20 Compression Gage Adapter
J 43244 Relay Puller Pliers
1. Ensure that the vehicle's batteries are in good condition, and fully charged.
2. Operate the vehicle until the engine is at normal operating temperature.
3. Shut off engine.
4. Disable fuel delivery system, by removing the EDU/IGN 1 relay withJ 43244 .
5. Disconnect glow plug nut; remove all 8 glow plugs. All 8 glow plugs must be removed from
the engine during each cylinder test to obtain valid test results.
6. Prior to taking a compression reading, verify the cranking speed is greater than 140 RPM. If
the cranking speed is below 140 RPM, repair the slow cranking speed condition before
continuing with the compression test. Refer to Engine Cranks Slowly in Engine Electrical.
7. Install the J 26999-20 in the glow plug hole for the cylinder that is being checked.
Fig. 42: View Of J 26999 For A Compression Test
Courtesy of GENERAL MOTORS CORP.
8. Connect the J 26999 to the J 26999-20 .
9. Using the vehicle's starter motor, rotate or crank the engine for 6 compression strokes, puffs,
for the cylinder being tested.
10. Observe the J 26999 and note the reading as the compression test is being performed. A
normal cylinder reading will be indicated if compression builds up quickly and evenly to the
specified level. An abnormal reading will be indicated if compression is low on the first
compression stroke, starts increasing on the following compression strokes but does not reach
the specified level.
11. Record the compression reading for the cylinder just tested.
12. Disconnect the J 26999 from theJ 26999-20 and remove adapter from the glow plug hole.
13. Repeat steps 8 through 13 for all remaining cylinders. All 8 cylinders must be tested to obtain
valid test results. Record the readings.
14. The minimum compression in any one cylinder is 2069 kPa (300 psi). There should not be
more than 345 kPa (50 psi) difference between a suspect cylinder and the average compression
of all 8 cylinders.
Normal - Compression builds up quickly and evenly to the specified compression for
each cylinder.
Piston Rings Leaking - Compression is low on the first stroke. Compression builds up
with the following strokes but does not reach normal.
NOTE: Do not add oil to any cylinder during a compression test as
extensive engine damage may result.
Valves Leaking - Compression is low
