Help: something wrong
fastgreek
238
Macungie, Pa
went to the track on friday, my truck went 1 /10th of a second faster than it did with the 4094 and the dual cp3's, i pulled the exact same 1.88 60ft , but my mph was 102mph where the last time it was 95mph( revlimiter was on), the truck was on level 9 then on level 10 (ppe programmer), 30psi turbo boost across the board, i had a fuel leak off of the line that comes with the twin cp3, tightened the shit out of it and it stopped, the lift pump was around 9psi. I know there is something messed up, any suggestions ........
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Problems
You need more boost but I think you have other problems also. Have you checked the commanded vs the act. fuel pressure? Is it smoking alot? Make sure your not bypassing fuel back. Just some thoughts. Jeff
slowlmm
Mar 2, 2008
2,582
46
so cal
you shouldent e useing a standard tuner for a 40-94 u really need efi or ppes 40-94 tunes. like said you need more boos should be makieng around 37 -40 psi check for boost leaks and get some proper tuening for the turbo
fastgreek
238
Macungie, Pa
well, i know whats wrong, we checked for leaks, loose clamps, not a thing, so i remembered a while back i downloaded files from ppe website and i didn't read correct that my tuner is not updated on line, i lost all my race tunes,so, i sent it back to ppe . That is most likely the problem.
