From Steve at the DP
"The small differences in a LLY Vs LB7 do not mean all that much. The LLY has a smaller injector so it will delivery less fuel than a LB7 it's a simple fact but some take it completely out into left field. Both turbo's are pretty close in overall flow so the injector becomes the limit. This is why a LB7 will make more power than a LLY. Once you change injector tips out it really doesn't much matter. LLY's had somethings that worked differently than a LB7 but since most could copy/duplicate the LB7 stuff most of the work was already done. Different day, different problem you just find them and fix them then move on."
Is that true? LLY injectors cant supply the same amount of hp as LB7's?
