Have a Airdog pulling from sump, Guage on Tee on Pressure side ( reads 5psi WOT, 10Psi Idling) where it splits to Valley pump Original(120k miles) and new ATS Dual belt driven pump. I see no air bubbles in the return from the two pumps, Changed the fuel Regulator on Original pump and new Fuel Pressure sensor.Had a second ATS Control box so swapped it out. . Injectors are new Lincoln 60%, Balance rates all below -2 at hot idle. Most of the time -1. I tryed raising the feed pressure 14 and does not help.
I am not getting desired pressure wide open throttle , goes above and below commanded 26,250 , mostly below and engine seems to surge or flutter at 3/4 throttle sometimes also. Rail pressure seems to jump up and down. Has a Race tune in it. 800-900hp. s366 with s480. I have a EFI data log if anyone could take a look or any Ideas where to test from here would be great.
