I installed my switch yesterday and all went well untill I had to push the ecm pins into the harness.
I found the wire isn't stiff enough to push the pin all the way in and the best way I found is to take the blue plastic cover off that protects the pins on the harness and pull the Dsp5 switch pins the rest of the way down. Also don't forget to de-virginise the pin hole by running a tiny drill bit by hand through the rubber.
I do not have a picture of what the harness looks like, If anyone has one please post it up.
