Is this something I need to buy for my build. I will be getting Carrillo rods so I will have everything balanced. But is this something I MUST have?
Thanks
Thanks
Thanks
That is the same thing Dustin told me. I don't have a RPM goal in mind right now. I would like to put twins back on when the money allows. But I don't see myself racing very often seeing how this is my DD and I wouldn't be able to hang with trucks like White Out in SS. I guess its good insurance just want to make good its a good thing before I drop the coin on one.
I have not added one to my truck yet also heads are stock. I have twisted mine to 5000+ a few times. If your short on money I would keep the stocker and add the new one later when you have the spare change.
so you dont have to balance the rotating assembly when you install one due to it weighing less? or will it be fine to add later since it will aready have been balanced?
FWIW, the first time my motor was balanced, it was done with the stock damper. Then the SoCal damper was put on and it was out of balance. I don't remember how much, but it was enough that my buddy who was doing the machine work had to redo it.
