someone wanna copy paste? My IP is banned from where Im at right now.
* * * Diesel Place Thread * * *
Thread : Smoke Switch
Started at 05-26-2008 08:10 PM by bb502cid
Visit at
http://www.dieselplace.com/forum/showthread.php?t=246763
[Post 1]
Author : bb502cid
Date : 05-26-2008 08:10 PM
Thread Title : Smoke Switch
i know the smoke switch is common with dodge and fords guys but i've never heard of anyone having it on the dmax.
i took some info off a dodge forum and decided to give it a try.
i have a 06 lbz running bully dog on performance and edge on 5.
anyways, basically what i did was tap into the 5v reference and signal wires going into the MAP sensor and hooked them up to a 2 wire on/off toggle switch. the MAP sensor is labeled so it was easy to determine which wires to tap. it does not matter how they are wired to the switch either.
the results on my first test run were fantastic, tons of on demand smoke. not sure how or if it will work on the freeway though. only issues i'm having so far is that the truck will sometime go into limp mode. according to the dodge guys i need to add a 10 ohm resistor inline to prevent limp mode occurrences. also the check engine light will come on but it doesn't bother me - i can easily clear it with the edge while driving.
i will add the 10 ohm resistor and post the results of that when i can.
i figured that i would share this info as some of you may be interested.
my main purpose in making on demand smoke will be for tailgators - although im not sure that it will work at freeway speeds yet but i will find out soon. i will attempt to post some pics or a video if i can get a buddy to ride along with me and snap some shots.
[Post 2]
Author : psyco66
Date : 05-26-2008 08:15 PM
Nice keep us updated.
[Post 3]
Author : bb502cid
Date : 05-28-2008 01:35 AM
i have not added the resistor yet but i was able to take it out on the freeway today.
bully dog on performance and edge on 5 - turned the switch on and gave it about 75% throttle according to the edge display - dumped smoke like a train. boost before i turned the switch on was about 4-5 psi and i was traveling at 70mph.
i've noticed if i don't keep the switch on for extended periods of time it won't go into limp mode. although the check engine light will come on immediately after the throttle is depressed with the switch on.
i will attempt to install the resitor by this weekend and post the results. ill also try to post pics of the smoke action.
[Post 4]
Author : Bodis22
Date : 05-28-2008 03:19 AM
My smoke switch works great at highway speeds. Called the pedal with a quad tuner on 110 or 135 tune
gets aggrevating though.
[Post 5]
Author : bb502cid
Date : 05-28-2008 09:57 PM
i don't have issues making smoke while pushing down on the throttle - again im running stacked (bully dog on perforamce and edge on #5). im sure any of us who like the smoke show don't have issues mashing the accelerator - what im trying to do with the "smoke switch" is to basically make smoke without the truck gaining speed.
something like that:
http://youtube.com/watch?v=AYaU1v1VIAc
[Post 6]
Author : blkgmcHD
Date : 05-28-2008 10:45 PM
bad A$$
[Post 7]
Author : exfrdlvr
Date : 05-29-2008 04:29 AM
this would be great for some yuppie in his bmw (broke my wallet) sitting at a stop light. or while going past some tree huggers!!! keep us posted
[Post 8]
Author : DrHolliday
Date : 05-29-2008 04:52 AM
I'm interested in this too, Any luck on the 10 Ohm resister?
[Post 9]
Author : fajitatone
Date : 05-29-2008 06:58 AM
that was like 10 bux in gas. OUCH! Smoke=Unburnt fuel which leads to insufficient funds.
but cool none the less.
Downloaded from Diesel Place (
http://www.dieselplace.com/forum) at 05-29-2008 12:44 PM.
The text in this document is Copyright © 2003-2008 Diesel Place. All rights reserved.
