Smarty tuner ( please dont throw anything!)
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
My nieghbor bought a newer 6.7 cumminGs and has been pestering me about a tuner.
Ive heard Smarty was the best Doodge tuner out there, am i right?
He has a stock 6 speed auto and will be ditching the DPF.
So should i tell him to get the smarty?
Any one here have a good price on one?
He's still gonna see my tailights!!!:coal:
UNBROKEN
Mar 30, 2008
565
Smarty is the king right now....it's adjustability is pretty much unmatched by anything else available right now.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
One of my buddies has an 07 5.9 CR cummins and the Smarty works well on it. Don't know about the 6.7s.
The hot setup around here for the 03-07 5.9 CRs is the Smarty-TST stack. I don't know if that takes the "2K and fall on its face cumminGs thing" away though. :eek:
on edit...Smarty also offers an adjust on the fly tuner.
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Let me know how it runs. My friend w/ a 6.7 has an edge running the hot program and is interested in getting the smartty. On a side not he is on his 3rd tranny in 30,000 miles:eek: so tell your buddy to be careful!!!
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
I'll let ya know, his wife is buying it for his fathers day pres.
Wow, i knew dodge trannies werent the best but i thought the newer 6 speed auto was a bit stouter than the older 4 speeds ?
Your buddie needs to see Mike L.!!
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Ive told him that several times. His truck has dpf delete and the edge that is all. It has ate two trannys both times completely fried all the clutchs. Either he has a lemon or those trannys are very weak.
UNBROKEN
Mar 30, 2008
565
I believe Smarty warns against using anything over level 3 on a stock trans.
Level 9 with the torque management on 4 and rail pressure cranked up will literally fry it in 1 pass.....not kidding.
Whitetail Addict
May 8, 2008
2,350
iirc level 3 is the recommended limit for the stock trans...could be wrong though.
The new "on-command" Smarty is adjustable...the way I understand it is that you can run any percentage of any tune. You load one tune then adjust the percentage...say 30% of level 4. I believe it to be similar to a DSP5.
On edit...that guy beat me to it.
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
My buddy has the edge w/ the hot unlock which I think is 100hp and it absolutly fried his shit. I would keep it around 45hp over stock.
Is there anything that can be done to the valve body to raise line pressure? I hear they have something like 40psi stock??
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
ATS has fully built trans that are available to the public already. The new Smarty has some issues but Bob is aware of these and Marco is working on them with a few people. Right now, there is nothing better than a smarty for a cummins.
1,866
I wonder if any of these can be used in a Med Duty application with an Allison? It sure would be nice to erase that speed limiter....:rofl:
