Could also be one of the the pressure sensors for the AC. Isn't there one or two of them in that same location?Green one is the air intake heater and the one below it maybe the wif or fuel heater?
There is a good shop down here in Houston called Scroggins. Probably other good ones as well closer.Very disappointed in the quality of "parts changers out there after my son and I tore this engine down. I hope there is a special place in hell for the guy who would use a worn out hex bit socket on an impact for removal and installation and even reused 4 that he had to use a chisel to remove! It gets better he used one of those chiseled allen bolt in the middle of the back of the oil pan, holding the flywheel adapter on! He even wanaged to pull out 2 of the inserts of the flywheel adapter. There were other shoddy install things, but reusing allens that were wallowed out is just plain stupid.
Alright enough of that the block turned out to have .020 Mahle replacement pistons and a 2003 date worn out cam that was also very tight, whoever RME of TX (was stamped on the freeze plug "overheat indicator" (I don't know the proper terminology is) I will definitely stay away from. I am shopping for a central TX machine shop to check out the blocks/cranks and heads
I will drive for a good shop, just checked out the nearest machine shop and got flashbacks from the machine shop I worked at when I was in college, even looked to have the same vintage machines, (our crank grinder had a serial plate from the Regia Aeronautica {a war prize} dated 1942! I know there is a small town added fee, but 95.00 just to hot tank (have a machined 392 Firepower that had succomed to TX humidity) 175.00 for a keyway on the crank, 350 to external balance if no mallory metal 450 plus the cost of the mallory metal if they have to add any. So they are pretty much out. I did find RME who rebuilt the engine from the truck and their reviews are just as I would expect them to be after tearing this motor down. So I am still looking for a closer shop first, then will check out Scroggins. ThanksThere is a good shop down here in Houston called Scroggins. Probably other good ones as well closer.
Thanks that was the idea, thing didn't even creak!Tell you what, I love that homemade wood crane. Doubles as a cool driveway decoration, similar to a pergola.
If they do quality machine work and have experience with machining a Duramax block, those prices are actually pretty good.I will drive for a good shop, just checked out the nearest machine shop and got flashbacks from the machine shop I worked at when I was in college, even looked to have the same vintage machines, (our crank grinder had a serial plate from the Regia Aeronautica {a war prize} dated 1942! I know there is a small town added fee, but 95.00 just to hot tank (have a machined 392 Firepower that had succomed to TX humidity) 175.00 for a keyway on the crank, 350 to external balance if no mallory metal 450 plus the cost of the mallory metal if they have to add any. So they are pretty much out. I did find RME who rebuilt the engine from the truck and their reviews are just as I would expect them to be after tearing this motor down. So I am still looking for a closer shop first, then will check out Scroggins. Thanks
Agreed, those costs are pretty reasonable. That's about what I pay here at our local machine shop. They do great work but take AGES to get it done.If they do quality machine work and have experience with machining a Duramax block, those prices are actually pretty good.
