Slight Miss/FPR?
JRein
Aircraft Mechanic's Hero
Sep 26, 2015
212
LRAFB, Arkansas
Any pointers? I notice when the converter is locked that I get a slight jerking, almost like cold knock, and am suspecting a FPR. It seems to hold alright at idle and is most noticeable at shifts. In the picture all the dips are at shifts. Am I on the right track or no?
picture.php
picture.php
picture.php
aashton1206
172
Are you tuning a tune, is it refueling appropriately
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Platinum AGM Duralast, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
JRein
Sep 26, 2015
212
LRAFB, Arkansas
That was another thought I had as well. The tunes were done by Rob in April and I noticed it a little when I flashed it back then but then it seemed to have gone away until now. I am planning on giving ATP a call but trying to rule out any hard parts on my end.
aashton1206
172
Log your autocal, check your desired to your actual. If it is within 100 kpas or psi then you fpr is fine. Call atp if that be the case and have them restore a little defueling between shifts
JRein
Sep 26, 2015
212
LRAFB, Arkansas
That's what is pictured above. At shifts I have seen a difference of 1-4K psi.
aashton1206
172
Try emailing atp first and see if that is a solution before spending money on a part I my suggestion
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Looks like a tuning issue to me. Send them some logs of it acting up. They should be able to fix it easily.
JRein
Sep 26, 2015
212
LRAFB, Arkansas
Update: installed an LBZ regulator this evening, shimmed the FPRV, and just did a run. Didn't notice any missing.
I do need to turn down my lift pump regulator now though as rail pressure is building when my foot isn't it which I find odd. I'll run some data logs and compare, hopefully in the next couple days.
Also idle is much smoother
Sent from my SAMSUNG-SM-G930A using Tapatalk
aashton1206
172
Check your tuning. Get a new base map with lbz calibration. The cascading rail pressures is a symptom of bad tuning
