Hi all I'm along time chevy fan(own three) and a second time dmax owner. Just bought an 02 crew cab 4wd with an 8 inch lift and 35's. Already had to do the transfer case back half(pump rub)..now 2 months later got the infamous injector leak, gotta love the LB7. Like most of you out there I barely have enough for the parts so I figure if I can put an engine together the injectors shouldn't be to bad to replace.
Has any one tried the industrial injectors? Also do you have to replace the injector tubes as well? It seems like it would be a good idea if you are already that far in there. From what I've seen the knowledge on this forum is top notch
** Kudos to ripmf666 for the articles**
Well thanks to all who can shed some insight, it's below 45 degrees outside so I'm not in to big of a rush other than that I sure miss my truck
