you'll get your chance next week when i'm hunting :thumb:LOL dont make me drive to your place and cut your internet off lol.Its hard keeping up when working 4 10 hr days and 3 out of 4 fridays and were starting 10 1/2 days next week. I will try and burn the iphone up.
I tried to give them every opportunity :coolspot:heck, you even disappeared for a while about a month ago...
you would'nt, would you :hug:If I can ever get the database to allow negative post counts all 3 of you will be in trouble. :lildevil:
Hmmm....
Rob, you used to be able to put in a very large #, and it would display a negative. But that does not work anymore. They filter it during input, so you actually have to hack it to get negatives.
I've tried a couple of things so far. Including changing the column type to something that should allow negatives. So far it will just go to 0, but I'm hoping inspiration will hit me and then I can have some fun.
Uhm, no admins are allowed in this thread :hello:
If it allows you to change the variable type, then change it to a double integer. A double integer (normal integer), will roll over at 32768?, and an unsigned double will roll at 65536.
Right now, it's a unsigned "double word" integer that caps at 2 billion.
