I have a weird shudder after the tourqe converter locks up an if Its locked I try to accelerate it will surge is the best way to describe it is my converter going it does fine off the line but does shutter or surge after lock up
No one piece an what am I looking for with a tech 2 just watching the lock.up
Yep sure am What else would we do other then keep at itwhat's up #1?? u at it again
Team Timex in the house
After my torque converter locks up, I see about -10 to 50 RPM slip at high throttle (-10 to 10 at low/no throttle). Does this count as zero? (Or, how much is normal?)Watch the PWM apply. It will come on in 3 or 4 stages. Once you see 96-97% apply you are locked. Once locked, roll into the throttle short of downshift and see what the slip speed is. It better be 0.
Worth noting: I don't feel anything unusual with that amount of slip.
Thanks!
~David
I was afraid of that... It's better when I'm not towing, but still out of spec.Do you mean -10 to +50? If you do, your converter clutch is breaking loose. I believe anything over +30 rpm slip is not acceptable. A good working converter will never see over +10.
