should i do nitrous
1slomax
Dec 6, 2011
260
Harrisonburg VA
been thinking about putting the bottle on my truck just to use every once and awhile just for if i run into somthing on the weekend, my mods are built trans,modded cp3,475 over stock twins, efi , pretty much it, whats everyone think should i do it?
Alliance1289
Apr 26, 2011
285
307
I don't think you will have enough fuel left over to spray. That 475 / stock probably runs pretty clean. If you did spray it, it probably wouldn't be enough to make a huge difference.
Dirtymaxx03
3,109
i run nitrous. stock injectors, stock cp3. But i am running a large single, so i use the juice to get ontop of the charger. You have twins so that shouldnt be a problem
MicksDuramax
Nov 13, 2012
69
PC,FL
Nitrous nozzle location
Where did you install the nozzle? I'm thinking pre turbo. Is this a mistake?
