Short er U-bolts?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Where could I find a set?Ive been looking around and can't find any in a 2.5" wide bend, or im just a retard...:rofl:
My 3/5 drop is nice but id like to remove another leaf out of each side on the rear, but I ran out of threads last time and had to use 1 washer on each bolt for it to have enough threads, which I don't wanna do again..
:confused:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
1/2 ton u-bolts or have a spring shop make you a set.
Doh, never though of that. Wonder if their as strong? Guess i'll find out. and I would rather buy new ones than to add threads to mine, last time I had to get the nuts off with a IR 1" impact... :eek: so Id rather replace them.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
1/2 ton u bolts are shorter and smaller diameter. i am at work so i cannot meadure them but are smaller.
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
how much lower are you going to go jesus man...you dont have a spring shop local to bend up some new ones....
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
Call Dunbar Spring 602.258.6901. They should be able to bend you up some. We use them for stuff the would gross 60k, so your truck shouldn't be a problem..
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
I cut off some schedule 80 pipes as spacers and then machined them in the lathe so they would sit flat. So far it's working well. But I can see where some shorter bolts would be nice, they do hang down a little even with just the overloads gone...
13,713
774
I would go to a spring shop and have them make some if it was me.
Ones from a 10 bolt wouldn't be big enough around for our axles would they ?
Our trucks use square U-bolts. As long as the springs are the same width, they'll fit.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I know some one posted this allready but most suspension shops build these to what ever size u need. Might not be the cheapest option but it is a a option.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
2" lower, and 2" from my axle tubes>frame. Might notch it if it's too close.
If you need a set shoot me a text Brian, Ill go pick up a set like mine and send them to you... :thumb:
Send me a pic with your tele phone.
Will do brandon, I'll give em a call monday. Might also go over to Cliff's welding over in Mesa since they have a lot of that stuff.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
I had planned on doing this since my "added nuts" look kinda jacked up. Don't think it hangs any lower than the caltrac mount.
:eek: Thats what I get for not looking before I type.
rcr1978
790
Spring Creek, NV
take a good look at the ones you get made before you leave the place that makes them. I had a set made and mine didn't touch the top flat portion of the spring they sat up due to the bend where they bent mine. :mad:
sparepartsracing
Mar 17, 2010
773
where did you get your drop from i think im going to lower mine..problem is im on 325/60r18's now
how low do you think i can go with them? my bumpers are trimmed...and my fender wells are cut and can be cut more....and i like uzing the grinder:rofl:
