Help: shop around dyresburg Tennessee....
624
Oil cooler on the engine let go.. Found extra 3-4qt of oil on the dipstick and good layer in the reservoir.
Be checking with delta GMC about oil cooler when they open
Looking for a place to wrench..
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I'm 4 hours from dyersburg in Missouri if that helps any.. At least you found your problem
624
Woke up to this..
Thanks for the offer! Local Cummins shop said I could use his place to wrench.. About 15miles away
Honestly I'd rather limp 4 hours towards home then 4 hours opposite direction.. Dealer said the can't get the oil cooler housing by close of business today.. Just 420.00 bucks.. Merchant has it for 384.00.. And PPE has the delete for 300.00
SmokeShow
6,818
Lawrenceburg, KY
Sounds like you have it covered but only place I know down there is Cedar City Diesel in Lebanon, TN (other side of Nashville from where you're at). Meechum is a really good guy though.
5,933
id be curious how your oil temps do without the factory oil cooler and towing big loads.
5,933
Oh I remember it but I've been curious what the oil temps will do without the factory cooler and just an aftermarket oil cooler for air-to-oil with a fan on it. I wasn't implying to run without any kind of oil cooler lol.
Watching temps, I can see oil and coolant following along with each other till thermostats open (oil always ahead of coolant temp though). Then pulling hills, you can watch oil temp climb to 230 and the fan kicks on. Once oil temps hit 240, coolant temp starts to rise. Oil then will go above 240.
Oil seems to put an extreme load of heat on the cooling system based on the gauges. Everyone seems to think the stock one doesn't work well at all but I feel differently. Only way to tell that is by running a cooler separate of the cooling system for the oil.
Hence my thought of running the Poe block off.
624
PPE has the delete a lot cheaper than the 460.00 I just spent with tax for whole new cooler.... .. Now is not as cheap as couple days or next week... Obviously
I run a more aggressive fan clutch than stock. Its on by 200°ect.. Oil temp above 215° the fan is on almost constantly. While ideally sticking a 925 or pair of 640s in front of the radiator stack wouldn't really help everything else... Truck seams to run better when oil is ~200°
.found these searching for setrab dealer...
http://www.racerpartswholesale.com/product/Setrab48RowOilCoolerFanKit/RacingShroudandFanKits
Only thing I don't like is they are right up on the cooler.. If they are set off 1-2" put more negative pressure across the cooler means better cooling
Right now. The current 60k of aux coolers IMO Isn't big enough to run by themselves... I'm thinking pair of setrab 640 coolers 12x12 basically pair of high flow 12" fans.... Currently got ~2000 cfm on 60k btu of coolers.. The plan/idea ~3-3500cfm on 120kbtu worth of coolers
Current setup
Pair if Jegs 10" 1000cfm fans they are divided so they can't cross pull
5,933
Your running the 6.5 fan correct? I need a new clutch on mine. I noticed last time towing it was not fully locking.
5,933
ooohhh very much so out here lol. with the external oil cooler, the fan doesnt come on near as often during the summer and ive noticed the a/c isnt as happy as before (high side pressures are higher than before as well). Thanks adam, sounds like ill like this bad boy
