Whenever I use my remote start system and go to put the truck in gear the truck says shift range inhibited and flashes the line under whatever gear I selected. As soon as I put it in park the check engine light comes on with the following codes: U1026, U1024, U1152,U1042. The truck is in Limp mode if you don't clear the codes. Any ideas on what could cause this?
